Hi all,
In the very near future I plan to purchase a set of 17" rims and tyres for my 1993 R33 GTS4.
Before I get my heart set on a certain set of rims, does anyone know what the correct offset is for my vehicle?
Currently it has 4 Stud 205/60/R15 (i think)
Thanks in advance!
chicane
:burnout: ;)
eeek 35profile tyres on 17's! i'd never go that low unless i had 18's +
Thats kool chicane, thought the were 5 something or other
no idea bout the offset of non turbo Skyline's, i'd imagine they'd be quite normal as there 4stud not 5, most multi fit wheels should go on, not to sure tho..
Just spoke to a guy @ donnellans, I think ill go past there on the way home today..
He said that the 5 Zigen's are pretty pricey as they are a fully imported jap rim.. but said there are quite a few other makes which are a bit cheaper with that design..
A guy @ one donnellans said its a 35/40 offset
another said its a 42 offset
so yeah
Hrmmmmmmmmmmmm anyone got any definites on this?
Cheers
This is what I found in my owners manual.
the offset depends on the width of the rim, any good tyre place will be able to tell you if the rim will fit properly as well as if the rim will handle the weight of the car... most 4 stud are only rated for small cars like pulsars and have max load of about 500kg so are not usable.
I ended up with 16x7 offset 40, tyres 225/50 92V (Toyo TPG) these also made my speedo more accurate..
Hi all,
After going around to a few tyre/mag places today, seems some places don't seem to care too much about offset..
In regards to maintaining the correct offset for my vehicle, with the 15x6" rims on there at the moment (they have an offset of 40mm), if I increase the width by 1" to 17x7" is this new offset calculation correct?
Increase of 1" width = 25.4mm
25.4mm / 2 = 12.7mm
40mm + 12.7mm = new offset of 52.7mm required?
Seems a lot of mags i like come with 40mm offset.. Is this OK to use?
Thanks in advance
chicane
:burnout:
