Hey,
Can somone please process my donation I have asked a few moderators to help me and havent got back to me on when they are going to do it???
Can you tell me whats going on is there a problem at the moment???
Is anyone else having this problem???
Jess :thumbsup:
https://www.sau.com.au/forums/topic/145880-where-is-my-donation/
Hey,
Jess :)
:sorcerer:
  • 3 weeks later...
I deposited a donation into the account specified in this thread http://www.skylinesaustralia.com/forums/in...?showtopic=4845
and PMd / emailed prank on the 4/1 (per his instructions)
i then pm'd him on the 5/1 and again on the 10/1 with no reply at all (either by pm or email).
Can someone help me out as i haven't heard back from him???
i donated maybe 1.5-2 years ago through paypal and it was never recognised in any way, i mainly wanted my PM box increased and i asked a few mods and emailed Christian about it several times and never got a reply.
Sorry mate, yours should now be fixed.
I pm a few administrators about how to be a trader, never got reply as well.
Shoot me an email - christian[nospam]@skylinesaustralia.com
Sorry dude, been flat out since the new year. All fixed now. :P
Thanks all for your support, I'm sorry it takes me a while to sort things sometimes, pregnant wife, busy work, I dont get on as much as I used to.
ANy other queries, just let me know.
Christian
Christian
Your email seems doesn't work/appear, so I send you an email already.
Thank you
Benny
  • 1 month later...
I got the same situation as you.
i know it will get done in time. just no reply to my pm's or e-mail.
Edited by Nebz
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
