sure everyone loves the idea of a 34 cruise / photoshoot but trying to get all at once in one place the problem...
suggest finding a date ...
a long weekend or week of no consequence ...
far from now ...
vic peeps arange an interstate cruise...
qld peeps arange an interstate cruise...
etc... etc... (see didnt forget about the west coast)
all converge at sydney for some sort of event ...
ie autosalon / jamboree / summernats / winternats ... ( i have nfi what sydney people do )
... far away from now so everyone can take it off work / family etc ...
... get a magazine interested ??!? ...
do a big meet go for cruise take photos whatever ...
goto event on same weekend (insentive for interstate travelers)
meh ....
other ideas people ???
so not off topic ...
Edited by gtt23
Hey gtt23,
is that the Top Secret(copy) front bar with Bomex sides n rears that u got? Any more shots from different angles? Ive been looking for the Top Secret front bar but none has comes close to looking like the real Top Secret one. The copy that ive seen around doesn't quite look right. Where did urs come from?
Hey gtt23,
looks like the standard bommex front to me.
That looks nothing like a bomex front. Its a GTR lookalike front bar from DMD.
Actually I think that front bar is an East Bear GTR bar for the GTT. Looks an awful lot like the version 1 bar with the standard non-vspec lip. Are you talking about the Do-Luck bar from DMD n15m0?
Anyhow so I'm not off topic heres the only good shot I've gotten recently of my car (phone camera).
sure is,
mock GTR front bar for GTT
by DMD
is the bar that came with the car so undecided if will keep / alter / or change all together ... but saving for tyres atm anyhows :stupid:
john.
