im in the process of getting moneis together so i can get bigger cams (not overly big) and valve springs to go with. :rofl: hopefully will get a nice amount of power then............so doesnt make the car seem like its "all show and no go"
not that i really care what people think on that topic
damn it sounds like ur real serious about pumping as much out of that NA as possible. have you ever thought of getting a turbO? not that theres anything wrong with ur NA, but the benefits would be alot more!!!
like i said though its a hot looking car.
yes i am quiets serious about keeping her n/a!!!!!!!
i do agree that yes the benefits of a turbo are there.........but i dont want to be like everyone else who has a turbo......
i have a plan that i am sticking too..........
do the cam shafts, valve springs, bearings too! aftermarket ecu
and see what happens! may end up being a rebuild!
  • 1 month later...
Hi guys, the weather was nice over the weekend so me and the missus took some shots in front of adelaide oval and the city east end.
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :blush:
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :)
Thanks mate, yeah caps stay on :) Unless it's like on an S14 or something or S15, it seems to go well with those cars without caps for some reason.
Hey Howie nice 34, Hey you have the GTR style rear bar dont you? Do u have ne idea if it would go with a impul kit? (impul front n sides with a GTR style rear bar) Cause yours seems to blend in nice
Cheers Tom, it's the factory option from the nismo catalogue, not quite GTR style. I've thought about getting just the impul front bar for the car, but wasn't sure about keeping the skirts, the rear though would probably look fine with it.
hey peoples my 34 is to leave Japan sometime this month i hope.....
anyway heres a few pics of it in Japan
very nice ride.love those rims.
hope you gona take that wing off....
please take that wing off.
Edited by fob2nv
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
