that ezyr34 is an r33! thats whats missing :D
Nothing gives that away :ermm:
Lol. I don't think thats whats missing.
ps. i can't put it in the R33 section, they'd kick me out :D
Edited by Owgasm
Haha, yeah, been looking for the front diffuser for months/years honestly!
The rear diffuser is a maybe if i can get one cheap.
I'm sure the problem is with most R34's that aren't V-Specs or missing the front diffuser is what makes it not look right.
One other way to tell its a R34 shell is its roof shape. I perfer it more than the R34 roof shape, its much more sleek and lower.
Hey all..some nice cars u all have!
Heres my old R34, sold her 6 months ago
Yeah, i remember this, seeing it at the Melb Autosalon earlier this year.
Saw it on the Dyno and must have been you with it.
my kit is bomex or bermex? i just picked it up 2weeks ago...
wtf r33 into a r34
is mine a fake r34? 1999 manaul r34 25gt non turbo >.<
how much is a turbo setup and is it easy to be done?
Edited by DeViLStaR
Yeah, thats what i ment about the roof shape ;)
Windows. geez, same thing lol.
Not as much as you'd think, but much cheaper than a R34.
Yeah, was based ona R33 GT-R V-Spec.
Also, the crease on the door, like basti said. For some reason you can see the crease clearly on it but when i see other R33's i can't see it :S
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
