didn't know this thread existed.... i guess i should put a pic up :D
hopefully getting some SLR type pics soon... in the mean time...
All genuine East Bear ;)
not sure if i need a spoiler, i'm leaning more towards YES, than No
It needs a badge in the middle of the front grille, but i'm not sure about a GTS-R badge, even though the kit is legit.... something about the R....
Sorry to quote the pics and all but people need to see that again, thats hot!
Perfect GTT I reckon, dont put a r badge on it, thats trying to hard.
Neil
My contribution :D
wow... looks so mean.. esp with that bodykit and fmic.. love the rims too.. so stealth! ..
Where did you take the pics? Looks like something from Need 4 Speed Underground.. lol
Edited by missusR34GT
Thanks for the nice comments ppl's, it was a long road to get here :( Forged, car is looking hot as ever :)
nah Howie, it's my original black R34 under all that East Bear :P
I um'ed and ahh'ed about finishing of the rest of the kit, but thought what they hey... something a bit different out there :) I *think* i'm still the only one in Oz with the full kit, but i'm not sure.
Not sure what to do with the spoiler at this stage...
DECIM8, i thought you were going wide body kit mate?
i was then i had a look at cars with wide bodies and in almost all could see screw holes :) im going to talk to peter again and see wat he recommends.:( in the mean time im making it a weapon mechanically :P the car looks great we'll see how i go with the wide body and go from there. Wish powerplay would hurry the fudge up
All genuine East Bear :)
No spoiler man, that looks fkn hot as is
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
