Here's my precious baby that i been looking after for 4-5 months since i got it. Hope you guyz like it :P
Fully Dump
19 inch
Top Secret Front Bar
Custom 20 inch
20 inch
Full Ztuned Kit + 20 inch
Few bit and pieces of carbonfibre
Stef you are a hoe :) hahah
Lol...not as hoe as you yet :P. As for the wheels im using the 20 inch at the moment, the time attack and ztuned wheels is on the way but thinking going to sale them. So see how it goes.
Hey R-Spec
Front bar is a nismo one, i cut out all the brackets and crap that hold the number plate and opened up the mouth, i plastic welded pieces of plastic around the mouth to make it look genuine, with lots of plastic filling and sanding, once painted, bar looks genuine with a differnence
not a fan of them z-tune guards but thats just sex on pornographic rims! :down:
any more/bigger pics? what front bar is that?
CNBLOW nice car wingless ftw needs more dumpage!
I'm pretty sure that's the do-luck front bar on the white 34 with the black cf bonnet.
Hey R-Spec
OMG... please sell me your bumper! :down:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
