Hey Adam, do you ever have issues with rain with the z-tune bonnet?
nice ride indeed + for the Z-Tune Bonnet
Hey Doski
Well i wont drive it in the rain but if i do there is a screw up undercover to stop most of (Not All) getting in and it came with the bonnet. and i leave the cover on as i never know if i am going to get caught in the rain somewhere.
Adam
Hi guys, got my Tein Monoflex coilovers and Nismo skirt kit fitted a few days ago. Heres some pics I took today:
See if you can spot my SAU sticker :D
My Volk GTC wheels will hopefully arrive from Japan late next week. I have a feeling that the GTC's will look better than my stock wheels :bunny:
Will post up some more pics when wheels are fitted. Cheers
Yeah mate, lowered it some. Cut a fair bit of the gap out between arch and tyre, especially at the front.
When they first put them in it was slammed, had to raise them up some.
Dont think I will lower them anymore than they are now as it would just be ridiculous for driveways, etc. The rolling diameter in my 19s that Ill be getting will lower the car a couple of mm more as the tyres will be 30 profile.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
