are those east bear tail lights?
Hey. Mate from what I have seen the East Bear, Just Jap, GK tech etc are all the same in design. No doubt in my mind they are all from the same factory.
wtf your front tyre looks flat!
Yeh its an illusion, the car is parked on the road and the concrete is higher. So its just the concrete covering where my front tire usually shows, so it looks like its on the rim.
Very nice Grant. Love the colour of your car also
Thanks mate, I have had a few comments about the silver since I posted these up around the forums :spank:
looks nice Grant, I really need a good camera, some photos ive seen on this site u can tell a good camera/location etc makes all the difference. Here i am with a 3.2mp mobile phone taking pics from driveway.. Awesome!!! haha lol but i guess if the car is sexy enough it wont matter :P love the colour and leds!
Thanks for the comments people!
Here is some more detailed shots of the rear lights if anyone wanted to see them
looks nice Grant, I really need a good camera, some photos ive seen on this site u can tell a good camera/location etc makes all the difference. Here i am with a 3.2mp mobile phone taking pics from driveway.. Awesome!!! haha lol but i guess if the car is sexy enough it wont matter :dry: love the colour and leds!
Certainly get a camera mate. But you dont need to spend much. I spent under $200 bucks and have used it for all my photos. Its not as good as an SLR of course but for car shots you can make cheaper cameras work.
But your correct, its really as much about the setting as the car. Blending both can create the overall good photo and really make the car stand out :P Im forever looking for new locations. I thought the big orange building would fit good on a dark night!
clean :P i see you've also got them LEDs :banana:
i cant stand wings/spoilers! i dont care how good theyre meant to look they'll never look as good as wingless + dumped!
not a fan of them rims too but overall looks nice
Edited by R-SPEC
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
