My R34 GTR (Silver) with Damien's R34 GTR (Midnight Purple) a few weeks back...
Seeing his sooooo makes me wish I had have waited for a MP one!! Hotness!!
Also a mention... My R34 GTR & R32 GTS-t 4 Door will both be up for sale very soon. Until the official advertisement is done, please contact me if you would like further information.
Cheers!!
Alicia xx
for some reason the gtr's just dont do it for me, im more interested in the simpler gtt's :D
and im lovin this one
dori34 you got any pics of the rear end/sides?
and specs on rims/tires thanks :bunny:
What you like on this one that you don´t like on a GTR?
What I see on the pictures is just a stockish GTT with GTR front bumper that doesn´t line up welll at the fenders...
for some reason the gtr's just dont do it for me, im more interested in the simpler gtt's :ermm:
and specs on rims/tires thanks :banana:
18x9 +26 235/40
18x9.5 +14 225/40
will have more pics when i get my new coilovers installed.
this is how i want it to look (different rims tho).
I don't understand, if you love that one and don't like the "complex" look of a gtr.... the one you've shown has a GTR bumper on it..?
Curiosisty.
haha id love to have the styling of a GTR anyday!
lol course i'd rather a gtr over a gtt anyday
BUT
imo this gtt looks better than say those gtr's posted above >_<
each to their own but ive always loved this look (not just on skylines) meshies/old school type rims, no spoilers, simple skirts, dumped!
btw dori34 wat skirts are these?
Edited by R-SPEC
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
