firstly i would have loved Damien to work his magic but when i booked Mavric i was under the impression FI was still closed later finding out they re-opened. so since i already gave my word to mavric i went through with it and ye very very very happy with it. i will also give FI a go later as well but wont be for another 6months or so.
as for the GTR kit car looks too plain atm so would love to get GTR front bar and decent skirts and z tune bonnet but then again dont really want an aggressive looking car as much as i love the look of the GTR something nice and somple will also be nice like a smooth flowing front lip and skirts.
fair enough. Matt's got all the good gear now anyway, so i know you had good products being used on your car.
i guess my question was, if you're going GTR, you gotta think about bonnets, front/rear guards etc, as skirts and front bumper won't just bolt/stick on with playing around in some other areas.
not if he gets a GTR fibreglass front bar thats made to fit GTT. but you will definately need GTR bonnet so a Z-Tune will finish the look off ;)
you might as well get Ztune side skirts & rear pods from JSAI to complete the look.
clean 34 you got ash! :D
As always, fantastic looking cars.
Heres 2 from the Bush Fire Cruise in qld on the 22nd feb - copied from other thread.
"I know this looks selfish, but when i got back, all the cars were gone hahahaha :down:
Sexy time.
sorry about size - they'll resize and fit into screen once it loads."
owgasm thats hot. someday my car will finally look like that lol
Thanks :P
Your car looks great, no need to do much more. :ermm:
like an r33 with an r34 front and rear end? lol
Hahahaha, of course.
He'll struggle getting the roof lower :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
