Granthem, is the bonnet alloy?
Its very very similar to my one - dad custom made it, test run on a yellow one (34 gtt, [eximporters]), then final one on ezy34. He cut up the original bonnet - crazy man.
Guess what. The bonnet is metal! Threw a magnet on it and sure enough she sticks.
So I guess chances are, I ended up with the bonnet your dad made for a yellow GTT. Its a bloody good job.
And it means far less trouble from the police, not being fibreglass!
SCORE :D
SCORE :cool:
Probably :P
Haha, nice, a few years ago, found a yellow 34, with a similar bonnet, also nsw.
Yep, far less trouble ;) Genuine part as well ;)
Enjoy it.
Ok heres my engine after the rebuild and taahdaah it looks stock standard just the way i wanted it (dont wanna get hassled by the boys in blue). Makes 310awkw now which is good i was only hoping for 300. Only visible difference is the pod cover and the diversion plate (needed it to hide new 100mm fmic) . Sorry about clarity was taken with my iphone..
Some more pics of my car :) now with wing removed and some mesh inserts removed from teh front bar. Frnt bar is looking a lttle worse for wear atm, driving behind trucks carrying gravel isnt a smart idea, neither is taking the M1 from the southside atm with all the loose gravel through the road works. ;)
no offence sammy but have you ever liked any other front bars? i feel like the c west you have atm is letting your car down so much. of course this is my personal thought.
liek you said its a bit beatn up so why not use it as an excuse to get something else ?
Out of Interest could your dad make another one of these bonnets? If so how much? Im sick of the stock look now I want the looks to match the go, going to blend with Impul full kit and perhaps wingless or GTR wing (I prefer the later, its just Impul drags the body down so much it seems to look better wingless)
i dont mind the cwest front bar but i have been looking into the do luck front bar
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
