This is worth reading...taken from wikipedia:
Z-Tune
Nismo originally designed the concept of the Z-tune in 2002 when Nissan was putting an end to the R34 Skyline production. The first Z-tune was built in 2003, using a used 2002 Skyline GT-R V-Spec II. It was built with a concept RB26DETT 'Z1' engine. This engine was based on Nissan's Le Mans GT2 and GT500 racing experiences. As with the racing vehicles a strengthened engine block and stroked crankshaft were utilized. The engine was also bored. With the new displacement of 2.8L and upgraded turbo-chargers the Z1 produced 370 kW (500 hp). The Z-Tune had a 0–100 km/h (0–60 mph) time in 3.2 seconds and has a top speed of over 195 mph.[citation needed]
Nismo was then given the approval from Nissan to build Z-tune models for the Nismo anniversary. Nismo then purchased 20 used R34 GT-R V-Specs, each with less than 18,000 miles (29,000 km) on the clock, they were then completely stripped and were resprayed to a "Z-tune Silver," a special color exclusively for the Z-tune.[18] For each of the 20 production models, the 2.8L engine was revised to allow it to reach 8000 rpm. The turbochargers were supplied by IHI in Japan. The engine is advertised as making as much as 370 kW (500 hp) (for warranty reasons). This second revision of the Z-tune engine is called the 'Z2'. The bodywork is designed with the same functional components used in Nismo's GT500 racing cars, such as engine bay vents on the hood and fenders, as well as wider fenders for wider wheels. The Z-tune is also improved with an aggressive suspension setup from Sachs, and a specially designed Brembo e brake system.
The entire car is essentially handmade, with the car being completely stripped and re-built from the chassis up. Engineers reinforced and stiffened the chassis seam welding in key areas such as the door seams and door frames and added carbon fiber to the strut towers and transmission tunnel and the engine bay, completely redesigning the suspension, drivetrain, engine, gearbox and other components so as to work at maximum efficiency and reliability as is expected of a road-going vehicle. Although Nismo planned on building 20 cars, they ceased production on only 19 (including 2 prototypes).[19] The Z-tune is often regarded as the most expensive (prices for some have been known to exceed US$180,000) street legal GT-R ever built.[citation needed]
Hehe...
Well there's a R34 GTR M-Spec waiting on the docks of Kobe bound for some lucky owner in Oz.
Great cond - great price.....
She hasn't been adopted ('er bought) yet, so......
I'll let Iron Chef Whispers tell the rest! :)
What colour is it Terry and how much??
May I allow Iron Chef PMs reveal the price, but I shall insert a couple of Pics now for you.
* It has done about 65,000 genuine Kms (Nismo cluster installed when new at Nissan)
* It is owned by a Japaneses motor technician
* It has full history
* It has had a life away from the salt of the sea or snow
* It won't be appearing in any Jap Auction as far as I know
* Modifications include GT-SS Turbs > 500HP (but I don't know what psi or RON)
From the outside it looks awesome, even the seats. But the engine bay is so dirty with quite a few mods. I guess it's for the guys who don't buying highly modified cars.
Although, there is/was an mspec for sale at xtreme motorsports in Sydney, it wasn't a millennium jade but more of a gold colour?
Edited by dlai
Out of interest, how would u rank from the least to most regarded r34 when looking at the vspec, vspec2, n1, z-tune, mspec etc?
I would go from the top....
Ztune
N1 (VSII then VS)
Nur Mspec (mainly for rarity)
Nur vspecII
mspec
Vspec II
Vspec
Having said that, rarity wise i believe there are more vspecs than nons... and today, i would still take a great condition non VS over a poor condition Nur...
just my 2cents..
Silica Breath perhaps? (see below)
beat me to it
But your post still prompted me to think,...
it must be a bit difficult to find what rims would suit Silica Breath...
I'm guessing that gold, titanium, chrome, white or even black rims might not suit that coloured car?
Perhaps just matt silver - hmmm, maybe bronze? Thoughts?
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
