My partner wouldnt do the sexy pose for me.. and someone had to do it.
Cut out my suggestive facial expression to keep this thread work safe.
Damn, I'm in love with your car. There's something just soo right about a clean, aesthetically stock BB gtr
Thanks Chris :)
They aren't bad rims Marko, not exactly the lightest wheels going around but they do look quite nice IMO
I'm thinking about changing to matte black Enkei RPF1's 18x9.5 +15 all around...haven't seen too many 34 GTT's with RPF1's.
Thoughts or recommendations for other wheel upgrades?
how much effort do you think would be required to make an 18x9.5 +15 fit. im looking for new wheels but am wanting good traction as well as offset, so id be looking for something like a 255 on a 9.5 +20 but i fear it would take to much camber/guard work to get them to fit properly. anyone running a 255 on the front of a 34 gtt? otherwise id look at a decent 235 on a 9 +20, but does anyone know of anything comparable to say an xd9 in this offset? cheers
@Spark, nice yellow 34! Is that the 'DIY Lip' I see used all round, even on the skirts?? :P
Was wondering what they'd look like on the skirts if it really is so haha.
On another note, too many GTR's in this thread...
... making me jealous!
thanks for the kind words guys, makes me feel proud of my canary mobile :)
definitely is the El Cheapo DIY Lip kit all round lol turned out okay but im currently in the process of getting together a kit for it
so YAY or NAY for black RPF1's?
ahhbee: would take a bit and money to go into the front guards to make a 18x9.5 +15 fit with 255 tyres...a 235- sized tyre however, makes it a fair bit easier to fit.
I have a good mate with a GTT who is running 18x9.5 +15 all round with 235/40/18 tyres. Rolled guards, camber arms (mainly to go between track/street) and the slight stretched tyre make them fit quite nicely. I'd simply spend more on a nice, sticky 235 than a ok-ish 255 and be happy with that
This will answer your question :)
Matt black would really set it off!
I like these rims because they are very well priced and different to what you would expect to see on a skyline. If I had an r34, I'd run these wheels.
I was even thinking of buying a set for my 32 but they don't suit the car as much with the high detail and intricate design.
index-15.php
Edited by Marko R1
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
