Cheers guys, Mark they're actually SSR Professor SP-1's but I can't tell the difference between the 2! The colour is midnight purple II but without any strong light on it, it looks almost black.
Awesome, may favourite colour!!
That pic with every model in it is awesome! Haven't seen that one before.
Thought some new shoes might warrant some new pics.
Quoted for sexiness (with this twice on this page already :P), dayum that looks good! MPII great colour. And excellent pics and the professors look sweet too.
Edited by kaitoukid
Oh, and a few pictures of our cars too maybe.
Ha.
Sounds like a plan mate hahaha...
I think the yellow and blue will compliment each other nicely!
You can take the pics but, as yours turn out better than mine
less pics of standard gtr's and more of modified ones please.
all standard ones are the same, changing the angle of the shot doesnt make it look less standard.
iwanta34gtr, yes your car is nice and clean but its still the same in every photo n same as every other stock 34 gtr
If it's such a problem for you then go buy a modified r34 gtr and start throwing up pics, otherwise stop bitching and enjoy the cars.
Okay, I wanna get you guys together and we gotta do some group shots somewhere!!!
Such fine examples :D
Spotless cars are a requirement haha!
A sau nsw r34 gtr group shot would be awesome, there are some very good examples within the club that is for sure!
Iwana, awesome pics mate, keep them coming!
Thanks for the feedback guys - positive and negative.
I'm new to photography but having fun learning and posting up the results.
My R34 is the only one I have access to at the moment sorry, all my other practise shots are of S15's - etc.
dont need a modified r34, already have a modified r33 gtr.
i am enjoying everyones cars but the last couple pages is basically just the same car from different angles is all im saying
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
