Beautiful car. Just curious as to what guard work had to be done to fit 10.5 +20 all round??
Is the clearance any different between a 4 door and a 2 door?
I spent about 8-10hrs on my guard work alone making the car about 25mm wider than stock.
also want to know, also camber specs if you have them please :)
I'll get specs as I've just been playing around with different ride heights and wheel combo's before another alignment.
Don't usually like sedans but well done. Have you thought about a roof spoiler?
How does the taillight cover appear at night?
Tail light cover is just a test ATM, aiming to make something more permanent soon.
Yeah thought about a roof spoiler, but I think it might ruin the clean lines.
Looks tough, love the dish!!
Here's mine just before I pulled it off the road again!!!:
Recently fitted bilsteins to get the height right :)
Also got bonnet struts and carbon radiator infill panel.
'Bayside' blue.
considering that we are both in Sydney, I'd be more than happy to pay u take some pics of my australian delivered r32 gtr. Ive always wanted decent pics of my car and your skill set is amazing. Would u be interested?
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
