Sorry its not the best, taken from ipad lol.
Well, well, well !!!
There she is!!!
The Winner of Best Concours at the R34 GTR 10th Anniversary!!!
Prepped by Eugene Chan. Btw did you receive a copy of the Certificate signed by Mark Skaife?
There she is!!!
Hey Terry, i have the award but there's no writing on it at all. I did recieve the calender though...
Damn Reece it is good to see this again
Hope she is running well
Hey Matt, She sure is! Cant thank you enough for handing her over :yes: Still yet to see a cleaner example of her :wub: lol. The ipad camera doesnt do it justice.
Good to hear. where is the build thread mate? :P
Need to see more pics...
Modified 34R skirts to fit gtt rear fenders ^
That looks tough! So many cars with the front end only and they really do look dissapointing or unfinished, you sir have nailed it :D
Haha whoops, I really should have stated that it isn't my car guys!
It's a car located in Japan that I'm using as the inspiration for my build (my car goes into the body shop very soon to get work done).
Nismo front with custom lip, flared rear fenders, MNPI respray, among other things.
I won't go into any more detail :no:
Ohhhhhhh :P
Well i look forward too seeing the result!
What rims will you be running with it etc?
The result should look like the above pic :)
CST Hyper Zero in 18x9.5 +15, which should be here hopefully by friday. Will post test fitment pic on standard guards.
May have to run spacers when i go wider until I buy some 18x10.5+15's
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
