R34s...please!
NS2500
Because POV spec lol
Currently making the front diffuser, should be on in the coming weeks.
Mad picture.
Oh ok just saw nismo side skirts.
A mate has a MNP III and got his skirts pods and spoiler colour coded, did an excellent job on the match for the flip paint; might be able to put owner in touch with spray painter if interested.
Love the black GT-Cs on the black.
The lip helps break it up, works well.
Matt, Noyz skirts are carbon and his lip will be as well. Not sure if he is wanting to paint them yet.
Cheers Matt,
If I ever need MPIII paint I'm all good, I have a local supplier for this. Can mix this perfect.
As Simon said the added parts I made are carbon so if I ever paint them it will just be a protective clear coat.
I'm happy the car is coming along slowly, Diffusers and Nismo front vents will be fitted in the coming weeks.
I may order a new lip from Nissan and get it colour coded when fitting the front Diffuser.
Noy
    • You have your numbers back to front. 350mm from wheel centre to guard lip would be scrapinly low and the suspension arms would be at spastic angles and it would have the road manners of a meth affected giraffe. You can down to ~450mm (from larger stock starting values about 50ish mm higher than that) before you start to create to many problems.
    • I think last I checked it was 35cm from fender to wheel center. I heard u can go up to 45-48cm before handling his impacted. But I need to check again. I know I was about 1.2 cm off being close to max recommended.
    • You'd need to weld on an external gate to achieve that number though. I can't remember seeing anyone make 500hp at the wheels with the stock manifold / internally gated turbo.
    • Suspension Component Question Looking for some feedback based on people's experiences! I know this has been loosely covered in other threads but I can't find any direct answers/experience. I'm up for some bush/rod replacements and was interested in a hybrid approach between hardened rubber and pillowball kit. Why not choose one or the other? Well, this is for my daily driver, which I track once or twice a year. I like a stiff car and a sporty feel but I don't want to compromise the chassis too much with 100% pillowball gadgetry.  I know from experience and a tonne of reading that not all components affect ride quality in the same way - eg. in my case, coilover top mounts should be hardened rubber as pillowball transfers way too many undesirable qualities and doesn't have much more upside than a good hardened rubber. But, pillowball tension rods translate to much better turn-in/steering response and make the car significantly sharper, without negatively impacting ride quality in a significant way.  I'm not TOO bothered by NVH (to a degree). So, with context out of the way, does anyone have any experience with a hybrid approach as mentioned above? I'm going to replace all components over time so am seeking guidance on: - front tension rods - upper camber arms - rear lower control arm - rear traction rod - rear upper camber arm - rear toe adjuster rod  Secondly, is there any reason why this is a bad idea? Or any other info/wisdom that I might not be considering. Cheers 🫶
    • That's good to hear I'll stick with the stock I hear they are good for 500hp and I'm only shooting for 350-400 once I can get this thing sorted and get to actually building it.
