some rare cars so i had to add this
wins the internet
actually been meaning to PM you, do you have any pics of your Z-tune diffuser off the car by any chance? or an underside pic perhaps when it's been on a hoist? interested to see the difference between the normal and Z-tune diffusers
A genuine nismo s-tune? lol. This is the fake car that rocked up at the lowdown showcased in sydney. Another one brought in by extreme motorsports to go with the fake nur that other sau'ers will be familiar. I am a huge fan of genuine nismo cars but this isnt one of them. End rant
Seems like you are good at talking Sh!t Mate... The S-Tune is genuine and the so called "fake" nur is my personal car that i have owned for over 2 years, if you have a issue with it, or myself you can tell me now.Who are you to tell me what badge i can have on my car, and for the record the car does have a Nur motor with a fair bit of work done to it and despite bullcrap going around the car was never up for sale since iv onwed it.
Post some pics I would love to see the car and ill know if its a nur as I used to own one
I might put some pics up soon it's a vspec 2 with nur running gear and half the nismo catalogue, I also know what a nur looks like..
I'm over people talking crap.
Edited by hypo32
Isn't it just a vspec II with a NUR sticker? That's from an outside view lol?
I notice the arc box, greddy hard pipe kit and oil lines (remote oil cooler). What other mods have u done?
Not my car Marko but this Nur (of God_speed's) also has...
* Torq-Lite carbon fibre prop shaft
* Nismo-Yamaha chassis dampers
* Ikeya adjustable control arms
* Nismo 19"x10.5" rims
* Ohlins top spec Coilovers
* Nismo Titanium exhaust
* Motec M800 ECU
* Nismo-Omori Titanium strut brace to replace the Kansai soon
* Trust hi capacity intercooler
* Nismo genuine skirts/pods
* Nitto oil pump
* Nismo kill switch cig lighter
* Jun cams and cam gears
* Nismo R-Tune C/F bonnet
* ATS triple plate carbon clutch
* Nismo genuine C/F rear wing blade
* Brembo big brake kit
Methinks you've seen this car before?
Will appear again this year in one of the car magazines + see next post.
Anyway, I'm impressed!
* NB This Nur to my knowledge had never appeared on SAU before 2012: but it did do a 10.9 at Cootamundra in 2009
*EOI
This Nur may be able to make an appearance next to Bobby's Z-Tune at J.E.M. on Wednesday 24th April if any SAU.NSW Members are interested?
This will be open to Members only at first!
So does anyone here in NSW want to see the Nur (above) and the Z-Tune on hoists?
Stay tuned to NSW > Events > Thread starts in March.
Many thanks must go to Bobbyr34 and other staff at J.E.M. for helping with SAU.NSW to stitch this together.
The SAU.NSW Tech Night will be about "Engine Builds".
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
