It's a wide body gtsr kitted gtt
I'd like the kit so i could get big rims and tyres under the car but am doing my best to retain the basic GTT look (I know this is the opposite to what most want to do lol)
I'm in the same mindset as you, I couldn't part with the nismo kit. It was the main reason I bought the 34
I actually chose against that kit as it looked too "bodykit" for me, i like plain jane cars (Hence mine looks so basic)... But i think yours is a good looking beast!
Just saw this on Facebook, interesting colour -
Silica Breath / Champagne Gold
Special colour for the M-Spec / M-Spec Nur
Interesting. Sunroof :/
Was it factory GTR?
It's a GTT.
East Bear "GTS-R" Badge.
R34 GTR Front Bar.
Custom wider guards / side skirt.
GT-Wing.
It's a GTT.
R34 GTR Front Bar.
GT-Wing.
You have a good eye for detail :yes:
You could always just buy some 20mm slotted wider front fenders from vivagarage and flare the rear guards?
I went for a cruise gtr front bar (because no one has it) and flared my rears rather than trying to mould gtr rear quarters on. I'm yet to see another gtt with flared rears in Australia.
It may not be basic gtt, but it's not trying to look like a gtr :thumbsup:
The only one I can see is a wild looking 25mm wider version... Would rather something a bit more plain :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
