It's a wide body gtsr kitted gtt
I'd like the kit so i could get big rims and tyres under the car but am doing my best to retain the basic GTT look (I know this is the opposite to what most want to do lol)
I'm in the same mindset as you, I couldn't part with the nismo kit. It was the main reason I bought the 34
I actually chose against that kit as it looked too "bodykit" for me, i like plain jane cars (Hence mine looks so basic)... But i think yours is a good looking beast!
Just saw this on Facebook, interesting colour -
Silica Breath / Champagne Gold
Special colour for the M-Spec / M-Spec Nur
Interesting. Sunroof :/
Was it factory GTR?
It's a GTT.
East Bear "GTS-R" Badge.
R34 GTR Front Bar.
Custom wider guards / side skirt.
GT-Wing.
It's a GTT.
R34 GTR Front Bar.
GT-Wing.
You have a good eye for detail :yes:
You could always just buy some 20mm slotted wider front fenders from vivagarage and flare the rear guards?
I went for a cruise gtr front bar (because no one has it) and flared my rears rather than trying to mould gtr rear quarters on. I'm yet to see another gtt with flared rears in Australia.
It may not be basic gtt, but it's not trying to look like a gtr :thumbsup:
The only one I can see is a wild looking 25mm wider version... Would rather something a bit more plain :)
