Haha yeah, you and your mates have impeccable GT-R's. :thumbsup:
thanks mate.....the Silver one is nice too...we are always giving each other shit..haha...i said no one was looking at his coz its not blue. So he wanted me to move next to him....hahahahaha
Hahaha happens to me when my car steals the attention from my mates fords/hsvs/beemers, gotta love that feeling! :P can't compare anything with these R's tho ;) and those photo shoot images came up so nice and crisp!!
So played around with my GoPro for a few minutes yesterday, these are some of the better ones. Will clean the thing sometime and try to get some nice ones.
1175674_10151566276907541_853880774_n.jp
1184979_10151566277472541_1905793543_n.j
that is one mean looking GT-T...but ufffff that engine bay is mint!
Looks awesome Raj, after looking at your car i'm considering adjusting mine to 100mm and contemplating eye lids, so tuff grats again man!
Raised by 15mm + "Street" alignment setup. Now she's sitting flush at 100mm from the tarmac - all thanks to Heasman Steering :)
E5975426-6CA0-4627-A014-7D57AE3665DF-241
SAU represent!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
