  • Replies 66
Posted Images
Hey dan, wondering when you are going to send my gear, it's been a month since i've payed you and you won't answer my pm's and i've recieved nothing. Whats going on mate?
  • 2 months later...
  • 2 months later...
  • 4 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
