Hey,
There are ppl putting r33\r34 fronts on stageas, so would you be able to do the reverse? (Stagea front on a r33)
What is involved with the front conversions to put skyline front on stagea? would it be pretty much the same process to do the stagea front on a skyline?
I just want to try and make a "unique" r33 which is damn hard to do.
Edited by R.B. Boy
https://www.sau.com.au/forums/topic/147279-stagea-front-on-r33/
The Stagea shares a similar chassis number as the ER34, being WCGN34, so dimensionly they are similar, but not the same
The Stagea front end conversion to R34 GTR uses custom guards to go from the Stagea door shape to the R34 front and a R34 radiator panel which needs some work to fit, along custom brackets to mount bonnet
If you were going to try a Stagea front to a Skyline the best car would be a R34 not a R33
I am half way thru a Stagea front end conversion
http://www.skylinesaustralia.com/forums/in...howtopic=137313
i rekon the stagea front is too square for the r33's roundness if u get what i mean. keep in mind tho i know sfa about stageas having never seen one in the metal b4.
either way i rekon that you would have achieved the impossible and create a unique 33 if u pull this off. keep us posted and good luck
In an attempt to make a r33 "unique"
Lots of other ways to make a 33 unique, but each to their own I guess. You might wanna get someone to photochop a stagea front on to a 33 before you even start. You don't want to blow all tht $$, time and effort and have an outcome that you're not happy with and make it even harder for you to sell when the time comes...
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
