Yep, I want to go to 5x114.3 on my r31 (aussie). I understand I'll need import front struts for the brake calipers, but I'm at aloss on brakes themselves? Can I run r32 type m calipers and front disks? What hubs? will the r32 ones fit? and then what about wheel offset-apart from clearance for calipers, will it change the offset, with the bigger discs, different hub assy etc? could I redrill R31 hubs? I would just be redrilling the rear flanges, dunno bout disks and calipers there though. Oh and what offset are R33 gts-t stock 16" rims, stock GT-R R32 rims, and gts-t r32 rims (but only being 6.5" I dunno if I want them)?
Mainly the fronts I'm worried about, anyone able to help?
cheers,
floody
Lambo,
I've just done the conversion to my R32 GTS25, you can buy the hubs complete, from SSS or Just Jap in Sydney... they are a straight forward swap over, the only problem is they cut the brake lines so I had to buy replacement lines for the rear, at $150... but you could get a locally made set of lines for about $60 if you didn't mind them not being perfect.
I swapped the diff over at the same time (to go to LSD) and the parts cost $2000 from SSS
That included:
4 x GTSt "Type M" Hubs
GTSt Viscous LSD
Half Shafts for new diff
If you didn't want the diff, it would cost btw $1000 - $1500
You're looking at about 6 hours labour to get it swapped over
I have just changed the rear diff internals and hubs driveshafts to gtr stuff on my gtst. So i have a 32 gtst diff viscus was not suited to 235rwkw but would be good for a gts and the driveshafts and hubs to suit. This will all bolt on to your gts and give you a 5 stud rear. Just need the rear disks and brake.
I want $350 for diff.driveshats and hubs.
