Spitfires or settle for 215rwkw
31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I have a moderatly tuned RB20 with the following mods
Sliding performance hiflow rb25 turbo
GTR injectors
GTR fuelpump
3" turboback, split dump, metal 3" cat
remapped ecu, FMIC ect
I am having a miss when running anything over 16psi with the stock coils (suprise suprise)...
I have ngk copper v plugs gapped to 0.8
Currently with 16psi the car is making 215rwkw. If I wind up the boost to 19psi it will not miss the first 2 runs and it makes 230+rwkw. the car also feels quite a bit faster. after that it all goes to s*^t
Should I stick with 215 and stop spending money or shell out another $600 for spitfires and be able to run the full potential of the turbo and make around 230rwkw
Is 15 kw worth $600?
or should I gap the plugs down further?
put the car back on the dyno today and had bad results due to the coilpacks.
The car only made 204rwkw due to only being able to run 13psi. the car did manage to make 5200n tractive effort but was serverley hindered by missfire.
the afr was perfect on 12:1 from 4000 to redline. so that and the 10 votes for spitfires and none for stockers :/ I have ordered the spitfires.
Really hoping for a solid gain and ability to run 18psi. The funny thing is I was able to run 18 for about 3 weeks and the coils have gradually gotten worse.
the car made 230 before the coils fuc$%d out so thats all I am shooting for.
I wasted hundreds of dollars with secondhand coils and remote coil setups, none of which solved the problem.
Haven't had 1 miss since installing the splitfires
DOOOOO IT!
I found perfectrun to be the cheapest - $535 delivered
Edited by Lazy-Bastard
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
