Im trying to get a decent straight answer here, everyone i ask has something slightly different to say.
Im wondering if R33 GTS25t's have a boost cut? If so, where?
I have been told that yes they do, but ive also been told that the ECU does NOT detect the boost at all?! (by the same people, at different times).
This kinda confuses me, as I dont understand how there can be a boost cut if the ECU cant actually tell what the boost is.
If someone can help clear this up for me it would be good.
Im getting a headache trying to work this all out.
Cheers
https://www.sau.com.au/forums/topic/147612-r33-boost-cut-ecu/
  • Replies 68
Posted Images
From everything i've read, most of the factory ECU's go spastic past 10psi...Some people say there's went fine at whatever boost they were running over 10psi so maybe there's some 'freak' ECU's....
When my car was dynoed just before the pfc was installed and tuned, they set it to 12psi...the dyno graph looks like a rollercoaster, and it certainly didnt drive like that with the stock ECU, and running 10psi....
The factory ecu does not measure boost, only airflow. The program in it is set so if the airflow exceeds normal operating parameters, the timing is retarded, and the mixture is enrichened. Also if the rate of airflow increase is too high, or it exceeds a certain point for a preset time, there is a safety feature built into the computer which wil cut the fuel. The boost sensor only operates the boost gauge.l
No, it doesn't have boost cut, it has Rich and Retard...
e.g. dump a heap of fuel in and retard the timing if you exceed the airflow threshold as said above (this happens when a turbo comes on boost to say 12 + psi with the stock ECU )... Result is massive loss of power
hrmm, ok, that makes sense.
my car went crazy on the dyno after about 10psi, so i guess thats why.
i guess ill be buying a pfc for xmas (if i can find one) and an external wastegate after that if i cant sort it out with the pfc.
yer nah dont think an internal gate is your problem.
dont see how a hiflowing exhaust would cause problems controlling boost seeing as the less restriction means the exhaust gases driving the turbinw wheel are 'getting way' nice and easy and there is no backpressure 'holding' the gases in the turbine housing.
using the standard 5psi rb25 actuator is probably more of the problem. i used one of them on my rb25 turbo on my 20 and boost was random so i used the 10psi from the rb20 and it was sweet
cos my car is overboosting atm, to close to 1bar, the standard gate cant control it properly - exhaust is too free flowing.
ive got another thread about it somewhere, apparently its a fairly common problem.
The stock turbo doesnt not suffer from creep, or any other problems.
It will be your boost controller. A free flowing exhaust has nothing to do with it.
no. its not my boost controller, ive been over that in my other thread.
and the rb25 actuator is actually about 7psi, as thats what it goes to without the boost controller in the loop.
and it boosts quickly & cleanly to about 7psi, then creeps up to about 12-15.
and according to nearly every performance shop/tuner ive talked too - it is definitely possible to have too free flowing an exhaust - it causes the turbo to spool too quickly, and the wastegate cant dump enough gas to control the boost.
im starting to think it might be the seperate pipe for the wastegate being too much of a restriction, so i might have to have a go at it with the die grinder and see what happens
adikt is correct, the stock gate is too small for the turbo, once exhaust and other mods are introduced. It is easier for the exhaust gas to go through the turbo then the gate, and hence you get creep. I am in the process of porting my stock gate 2.5mm either side, enlarging the area by 38%. This will be a big difference. and the stock gate is DEFINATLY the problem. It's more of a problem on the R33 the R32.
As for boost controll, if you wire teh gate fully open, it will still creep, this is because the gate is too small.
because it comes down to the design on the exhaust, if the exhaust is such that the cat and the bends and the dump, cause sufficient enough restriction in the system, the gas will want to flow through the gate, or to put it more presisly, it is forced to go that way, as it it easier to do so then to go through the turbine with has restricted flow. When the exhaust is so efficient, that it is easier for the exhaust gasses to go through the tubine and not the gate, as there is no restriction, that is when problems occur.
THIS IS A VERY COMMON PROBLEM, especially on SUBARUS and EVOS, when you change the dumps and get high flow or run no cats at all.
Not only is the exhaust a colprit, but if you run a FMIC, then the problem is worse. As cooler air means more dense air, esspecialy on cold morning, the turbocharger does not have to work as hard to compress the exhaust gases, and boost is made eaven easier. On such cold days with an FMIC, it is not uncommon to see a 5psi boost creep. This is to do with the fact that eaven though the gate is fully open, the gas is not going through it to regulate boost.
Now ther are things you can do, like getting an aftermarcket BOV, and regulating some of the boost that way, adding a restrictor plate in the exhaust, commonly done on RX7's. But the true fix is the internal gate, this is providing that you have tested things like the actuator and the arm and the gate for damage.
To port the standard gate, is no biggie, just a pain in the ass, as the whole turbo needs to come out, but seing as i can make nearly
210-220rwKw with a stock turbo, and the other mods i have, i am happy with keeping it as is.
Hope that anwsers some of the questions.
External wastegates are typically for turbo's that don't have internal wastegate. If you think you have a wastegate issue, then you probably need to modify the one you have, i.e. increasing the flow through it by porting it, and a new actuator.
ive been ringing around today trying to find somewhere that will port my internal gate.
they all say they wont do a rb25 turbo, but do lots of others - evos/wrx/mazda/etc.
have to keep ringing around, unless anyone happens to know anywhere in NZ that will do it?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
