hey guys, before i go buying, just wanted to get a certain answer,
my 1993 R32 gts-4 requires a completely new exhaust system as the current standard pipes have rusted through and are leaking, i want to replace the whole system with a nice stainless catback system, and some form of split dump/front pipe like a BATMBL one
however alot of things on the car are gtr spec, for example when i bought the new suspension i had to make sure i got gtr suspension as gts-t suspension would not fit, is the exhaust in the same boat as my suspension?
like do i need a gts-t dump/front pipe and then a gtr catback?
what is the go?
it would be good if someone could give me some ideas on what to get :P
cheers
-Ruffels
Edited by Ruffels
https://www.sau.com.au/forums/topic/147695-r32-gts-4-what-exhaust/
R32 GTS4 is turbo (RB20DET). R33 GTS4 is N/A (RB25DET would have given it performance too similar to the GT-R).
The suspension is really the only stuff that interchanges with GT-R. Everything else is GTSt.
R32 GTS-4 uses GTS-t cat backs, though you;ll have to bang one of the support bars a bit (easy to do on a hoist, or get an exhaust workshop to do it. Shouldn't cost more than $30)
I have an R32 GTS-4 and decided on the batmbl front/dump, a highflow cat and an HKS silent cat back from nengun. Putting it together is an easy job, except for that one support bar.
I've heard that you can get a decent custom one made form most exhaust places for under 1K, in the end it's up to you. It's really just a pipe, and I could have saved money by avoiding a brand name, but hell, I've got no regrets. I love the note, and the full stainless from the turbo back.
There is a guide in the tutorial section on how to fit an exhaust also. It's a great one to use.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
