I've got a single Gull Sports reclinable seat (a lot like Recaro), its got a few small holes as per the picture but 1/2 of it has been recovered. Mounts up to Recaro rails and some Bride rails. Very very comfy as most of these seats are. $230 neg.
post-4038-1166437630.jpgpost-4038-1166437680.jpgpost-4038-1166437722.jpgpost-4038-1166437759.jpg
Also a pair of RB HKS Cam Gears, only done dyno time on two.06l. These are the older style so as long as you run with the cover fitted and timing belt tightened to factory specs they'll be fine. $270 neg.
post-4038-1166437801.jpgpost-4038-1166437839.jpgpost-4038-1166437880.jpgpost-4038-1166437928.jpg
PM me or email [email protected]
https://www.sau.com.au/forums/topic/147847-gull-sports-seat-hks-cam-gears/
No it doesn't come with rail and its a single seat.
I'm in Toowoomba or Gold Coast depending on the day. If you're serious i could put it in my car when i come down that way next (will be driving to GC on Wed morning and back on Fri night or Sat morning).
My bad. Thought you had 2 for sale. It seems I need some sleep. Thanks anyway.
Depends how wide i spose :teehee: I'm fairly tall and skinny and i've got room to move, i just got my brother who about 3" shorter and 20kg heavier to try and he found it snug, but not uncomfortable.
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
