There was a bloke in Victoria who had a 33 that was supercharged, he would come to cruises occasionally. From what i understood his setup was quite limited in terms of the power it could make, possibly stock NA internals im not really sure. Thats about all I know apart from the fact it was black with some terrible Fast and Furious/Transformer graphics all over the side.
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2762191
check out the naturally aspirated performance section
someones dropped a v6 and supercharged it.
I actually am looking for info about supercharging a RB engine..
not sure if I'll go that route.. but just looking for more info =)
cheers
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2762555
my twincharge is basically a supercharged RB25/30 with a turbo added, so all the principles are very similar to running just a supercharger - except this is vastly better:
there's more info here:
http://www.calaisturbo.com.au/showthread.php?t=79101
http://www.calaisturbo.com.au/showthread.p...ight=dyno+today
http://www.performanceforums.com/forums/sh...ight=twincharge
cheers
Edited by StockyMcStock
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2763932
it looks interesting mate..
how much did you have to spend to get a supercharger on it?
and how the 2 run together?
cheers
cheers
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2764320
i bought the blower from USA ebay for $300 AUD delivered, they came standard on a heap of cars over there and are hence much cheaper than here in australia. the later model ones also have improved internal design which is nice.
after purchase price, i had to have the drive snout shortened by a machinist which was $200. i bought some steel for 20 bucks and made the brackets myself. tensioner bearing was maybe another 30 bucks.
the other main cost is in the billet pulleys you can see in the drive system. i used a pair of cam gears and had a toolmaker lathe up some billet pieces for them to bolt to. there is a cam gear bolted to the crank, and another on the end of the power steering pump shaft. this is then bolted to the billet 8PK drive pulley, and the whole lot has a single retaining nut on the power steering pump shaft. it's a very neat system and allows for clearance to the radiator and other things which i won't go into. this was $500 for all the machining work.
you could certainly do it cheaper, but i wanted this setup to be very reliable and well balanced, which it is.
running the blower only is great, until you get the revs up. the lack of top end power will only be disappointing to your average punter. it drives a whole heap better on the street though, with bulk low-end power.
fitting the turbo only was the opposite, massive top-end power but nothing below 4000rpm.
with the two combined, and the multiplying effect of the two compressors, you have a very nice end result - as seen in the power delivery on the dyno. an almost ideal power curve of that shape, with that peak power on that boost level is just not able to be replicated on any 25/30 i've ever seen. the torque delivery is flat as a tack, so no matter what RPM you're doing you have the same torque at the wheels. this makes the car much easier to drive, and stay on the edge of wheelspin by controlling the throttle.
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2764618
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
