There was a bloke in Victoria who had a 33 that was supercharged, he would come to cruises occasionally. From what i understood his setup was quite limited in terms of the power it could make, possibly stock NA internals im not really sure. Thats about all I know apart from the fact it was black with some terrible Fast and Furious/Transformer graphics all over the side.
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2762191
check out the naturally aspirated performance section
someones dropped a v6 and supercharged it.
I actually am looking for info about supercharging a RB engine..
not sure if I'll go that route.. but just looking for more info =)
cheers
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2762555
my twincharge is basically a supercharged RB25/30 with a turbo added, so all the principles are very similar to running just a supercharger - except this is vastly better:
there's more info here:
http://www.calaisturbo.com.au/showthread.php?t=79101
http://www.calaisturbo.com.au/showthread.p...ight=dyno+today
http://www.performanceforums.com/forums/sh...ight=twincharge
cheers
Edited by StockyMcStock
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2763932
it looks interesting mate..
how much did you have to spend to get a supercharger on it?
and how the 2 run together?
cheers
cheers
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2764320
i bought the blower from USA ebay for $300 AUD delivered, they came standard on a heap of cars over there and are hence much cheaper than here in australia. the later model ones also have improved internal design which is nice.
after purchase price, i had to have the drive snout shortened by a machinist which was $200. i bought some steel for 20 bucks and made the brackets myself. tensioner bearing was maybe another 30 bucks.
the other main cost is in the billet pulleys you can see in the drive system. i used a pair of cam gears and had a toolmaker lathe up some billet pieces for them to bolt to. there is a cam gear bolted to the crank, and another on the end of the power steering pump shaft. this is then bolted to the billet 8PK drive pulley, and the whole lot has a single retaining nut on the power steering pump shaft. it's a very neat system and allows for clearance to the radiator and other things which i won't go into. this was $500 for all the machining work.
you could certainly do it cheaper, but i wanted this setup to be very reliable and well balanced, which it is.
running the blower only is great, until you get the revs up. the lack of top end power will only be disappointing to your average punter. it drives a whole heap better on the street though, with bulk low-end power.
fitting the turbo only was the opposite, massive top-end power but nothing below 4000rpm.
with the two combined, and the multiplying effect of the two compressors, you have a very nice end result - as seen in the power delivery on the dyno. an almost ideal power curve of that shape, with that peak power on that boost level is just not able to be replicated on any 25/30 i've ever seen. the torque delivery is flat as a tack, so no matter what RPM you're doing you have the same torque at the wheels. this makes the car much easier to drive, and stay on the edge of wheelspin by controlling the throttle.
https://www.sau.com.au/forums/topic/147935-supercharger/#findComment-2764618
    • 😍 Yes! (but no! 😢 )
    • Yeah but they dont look like this, which is GOOD.
    • What magic did you work to end up under half the amount you were quoted?
    • I only just let our 2007 (post face lift) GTB Wagon go. With 2.5 turbo, and 6 speed in it too. The Subarus, especially in GT guise are super nice cars. Great on the highway, and no matter what tyres, or what surface you're on, just throw them at a corner, and they go.   Unfortunately ours had a minor accident, I started repairing it, but priorities changed due to an opportunity that came up. Sadly, sold it to someone who just wants it for the drive line to swap into their WRX to replace the 5 speed in it with a 6 speed.   Definitely share more of the B4!
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
