I too want to wish everyone a happy and safe Xmas.
Thanks to everyone for making 2006 a year to remember - have definately come away with some fond memories and some new friends.
Enjoy the Festive Season and be safe on the roads.
PS. Hope you all get some cool pressies :)
https://www.sau.com.au/forums/topic/148075-xmas/#findComment-2768365
I want to wish all a Merry Xmas and a Happy New Year
Be safe all, and if ur Geelong Bound and see a WRX with SAU Sticker's give us a wave.
Cheers
Andrew
Merry Christmas everyone - Have a safe one!
I'll be Eastern Beach bound christmas day - wave back if you see my R32 with SAU stickers :)
Cheers,
Steve.
https://www.sau.com.au/forums/topic/148075-xmas/#findComment-2770584
merry christmas all. hope you have a wonderful day and get all the presents you hope for.
went out last night to check some of melbournes christmas lights for something to do
check out this house in vermont
like f**kin disney land, it was intense
https://www.sau.com.au/forums/topic/148075-xmas/#findComment-2773095
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
