600kms From Tank
Geez, 500 - 600ks from a tank thats something I would never imagined in my r33...
I did a test driving like a granny shifting always through one tank at 3500rpm and aonly got 375ks and that was really trying... I;m running pfc and 3.5in zorst... the rest is pretty stock...
Maybe I should get it tuned again.. I've asked three different shops to retune and they all say nah I wouldn't retune it its pretty damn right on...
maybe I'm just a lead foot and don't realise or my tacho is lying...
a few things to note
cruise AFRS should be tuned (usually under 3 grand is the spot to be tuning)
make sure 02 closed loop feedback is on
make sure you have a working 02 sensor (replace it every 50,000k's, if youve never done it, get a new one now)
dont vary the throttle over and over, keep a steady foot
dont boost the engine up, engine load uses more fuel
sometimes it may be more economical to run at say a bit higher rpm and less load then lower rpm and higher load
ie:
2900 rpm with load row 5 in 4th gear
vs
2100 with load row 12 in 5th gear
it also depends on where you live. i live in a pretty hilly town, so while i spend some time going down hill at little or no throttle, i also spend time going up hill at a much higher throttle percentage.
the best economy i have gotten was 410k's to 45L. that was about 80% highway, and 20% hard driving round town (a little bit of that with a car full of people). thats just under 11L/100ks.
i cannot see why a different octane rating would yield different economy? i would love for someone to show me how ?
best ive got in my r33 pfc was 550k's to a tank, and it wasn't empty
Cheater :ninja:
That was when you were cruising to Sydney at 110km/h all the way
What is your average milage?
I get about 320km to a tank, with 260rwkw, but my car is a weekender (not even sometimes :) ), so when i drive it i like to drive it :laugh: , fuel consumption does not bother me at all. If i want to save fuel, i leave the car in the garage and take the company car :) .
average milage is 400k's to a tank with 02 feedback turned on now
nothing cheating about it :)
the drive to sydney was with 02 feedback off
ive since turned it on and i was a bit suprised its given me some better economy on the street ,even tho my normal afr's are pretty lean
ie:
vs
That doesn't tell you much though! Best way to judge fuel economy is to sit at speed in various gears and note the injector duty cycle!
Btw I experienced notably better highway fuel economy when leaned to ~15.5:1 AFRs by switching off O2 feedback and adjusting the IGN/INJ trim.. I'd only advise it if you have a wideband though....
the best way to judge economy is with a wideband
but yeah i did the same, tuned afrs with closed loop off
i wouldnt be using inj duty as the way to work out afrs, althought it can be used to "guesstimate" them
i get about 520ks to a tank, and it's not empty when i fill up. i use shell vpower. those are city k's, up/down hills etc.
r32 gtr, mods: mines ecu, steel wheel turbos, turbo back exhaust, 550cc injectors, greddy oil management, trust air pods. i have a powerfc ready to go in.
i reckon i could do better but my twin plate clutch means i have to give it some juice to move off the line.
edit: 520 kms / 51 litres used = 9.8l/100kms.
Edited by sigsputnik
Another way of looking at it:
I get better mileage out of PULP on my bike, if I have to use ULP I hit reserve 25km earlier. I try to use PULP all the time, cos I can get that bit further [motorcycles aren't made for pushing] and get to the next town.
The economy doesn't add up to the extra cost, PULP is more expensive no argument. But the convenience of not having to 'short fill' = being able to make the next town makes it worthwhile.
Not everyone agrees on this one but I feel my R33 could do with a slightly taller final drive not so much because I want to have taller overall gearing but because I'd like a bit more load on the engine at round town speeds . I find myself short shifting this car all the time but then my style of driving is probably different to most . I like the idea of more load on the engine so throttle is opened a little more and dynamic CR a little higher . By using V power racing 100 pump fuel and tuning the engine exclusively for it both consumption/power AND throttle/boost response should improve . For the twenty someting cents a litre over power kero gade unleaded I can live with this . I might add my car is not daily driven either , have a nearly dead roller skate for general use .
Cheers A .
Cheers A .
Got to agree there,
I've allways thought that - I've allways been annoyed with the short first gear - to keep up with the Jonses in commo taxis etc you end up doing 4000rpm gear changes 1st to 2nd all day long - gets annoying all day everyday and must be a bit hard on the synchros stopping the gears all the time.
My best rb lazy drive was my old clapped out vl na 5 speed - heaps of tourque and you weren't doing first to second gear changes in the first 10 metres.
Cheers
Edited by gtst25
Guest 40th-edition
sorry dudes, havnt got a computer at home...
iv got 3" zorst, fmic, boosted to 11psi.
alot of my driving is h/way living 33kms from work so it is cruzing alot of the time but also some around town driving... nothing unushual that what i use the v-power fuel for.
just seems to get a noticable diffrence in economy.
one bad thing is i dont have that fuel any where in my normal day to day area of driving.. need to go min of 100kms away to get it, so by the time i get home its about the same! lol...
cheers for the replys
i get about the same top speed out of each gear in my skyline as i did in my 180sx, the missus SSS pulsar, and my old 5 speed falcon. the nissans just rev a lot harder to do it. but the falcon at 4000rpm sounds like its reving a lot harder than the nissans
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
