OK in the past 2 weeks ive been defected 2 times.First time was for blow off valve.
Second time was for exhaust and my HIDS.
The first copper said my exhaust was fine but not to go any louder.
The second copper was a prick and wrote me up anyway.Today i went to get it tested and i was 4DB over(shit) so i went and got a standard exhaust put on.But the thing is i have to give it back in two weeks(loaner)
Seeing as my other exhaust was only 4DB over what can i do to it to make it quieter without comprimising flow.The standard system has robbed so much power out of my car its not funny.Can anyone in the same boat help me out?Options? Is there quiet high flowing systems on the market?
CHEERS
Dave
https://www.sau.com.au/forums/topic/148346-defects/
I guess ill have to try the centre muffler option.Going from high flowing to standard exhaust is a huge decrease in power.Amazing what a high flowing exhaust can do for turbo cars.
Edited by NYTSKY
https://www.sau.com.au/forums/topic/148346-defects/#findComment-2769671
yea bud the best option is to get another centre muiffler as the others on here have said... the hks super dragger exhaust i have has a centre muffler and a hotdog aswell... its pretty quiet so that should do the trick for ya
My one is a fujitsubo.the guy testing it was suprised that it was over cause its pretty quiet.The standard one i have on now is 88.5db. My aim is to find a system that is 90db but provides the same flow as my fujitsubo one.There must be a market out there for legal yet high flowing exhausts.
Edited by NYTSKY
https://www.sau.com.au/forums/topic/148346-defects/#findComment-2769736
Now on the subject of defects.I have an intercooler in the garage ready to put on.Are they a defect.A hole has to be cut into the engine bay to fit it.
If you're cutting a hole in the engine bay you're going to have to get that engineered, otherwise = defect?
(Going by what happened to a friend of mine)
https://www.sau.com.au/forums/topic/148346-defects/#findComment-2769969
Go to Mr. Muffler - get a Muffler that's within the legal DB limit - get the guys to write you up a report stating that it's legal - make a copy of it and keep it in your car...
When a copper pulls you over - show them the paperwork and that will shut him up.
That's what I've found...
https://www.sau.com.au/forums/topic/148346-defects/#findComment-2773850
Simple get an exhaust that complies.
There are some made by kakimoto and fujitsobo that are legal.
they have a 92 or 96 suffix on the model names.
can't just get an exhaust that applies, it needs to be engineered to say that it comply's with the australian design rules.. i was defected for my exhaust, and mind you my exhaust is under the dB rating.. i was told that if i didn't have a engineered certificate to say that it complys with the australian design rule then they can keep defecting me..
simple answer: Either know someone dodgey to clear it like i did... or put the stock one back on.
https://www.sau.com.au/forums/topic/148346-defects/#findComment-2776038
This is true. Although, if you are defected for noise - my solution would suffice.
If you are defected for no ADR compliance - your solution would be the only one.
https://www.sau.com.au/forums/topic/148346-defects/#findComment-2776057
  • 4 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
