My r32 doesnt go to bad, its not level but the turbo doesnt get a full length on me, but the turbo i raced has a few probs to iron out, my cars got a 2.5ltr so yeah its a evenish comparision for the r33, mine a bit lighter though, got nfi what the power is though.
AFAIK, when Nissan released the R34 range they decided it was time to give the old RB series a bit of revamp - hence the introduction of the Neo Strait 6 engine. In addition to various other improvements the Neo engines got VVT, however the GTR's RB26DETT did not. (this may be the reason that Nissan can get away with quoting the official power output of the R34's RB25DET as 280PS & the the R34 GTR's RB26DETT at 280PS also!:mad:
I have seen 1, R33 series Skyline (late model) that had a Neo strait 6 engine in it - whether Nissan officially produced the R33 with the newer Neo's in it I can say - it could have been a conversion or something as simple as bolting on the "Neo" plastic engine cover...
Cheers
Dave
HPI has road tested an NA GTS25 against an NA Supra, their figures show 0-100 in 7.3 and 1/4 mile in 15.5 which is accurate in my case cos ive done my 0-100 in just under that time and the quarter sounds right. the car made 105 kw at the wheels, this is stocko with a muffler i think, pretty good i guess, id like 150 at the wheels on mine
  • 3 weeks later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
