So yeah, my car. Its red. 2nd pic is the one before it left japan with the front lip, which seems like its going to get repaired in the very near future!
Last one is of the sound deadening half compleated :teehee:
So yeah, I could put the mod list up, but I really dont want to because I dont have that much time to waste.
https://www.sau.com.au/forums/topic/148468-dds-cef/
  • 3 months later...
List of mods that I can think of.
'turbo' boost gauge (thats what it says on it)
Hardcore racing bleedvalve set at 12psi.
R34 side mount intercooler. (which btw bolts right up, no hose changes at all)
Malpassi fuel reg set at 32psi at idle (best for responce power, and fuel economy)
Bit of 3inch pipe from front bar (hence zippy tie on front bar) to pod, works VERY well.
KnN Ms pod (huge bugger) also mesh removed from front and back of AFM.
Spun Alloy catch can.
Dump pipe back exaust, I 3inch in to 2 big arse mufflers, so its 84db at 4000rpm nice and quiet.
Bigger fuel pump, prob GTR.
RB25DET gearbox, with redline shockproof oil.
GTR flywheel.
Jim Berry Carbonic 5puc cluch.
Nismo GTR pressure plate (3600lb clamping pressure)
Braided clutch line.
2way mech diff.
1990 R32 motor.
Dr Drift chipped ecu
155rwkw before the intercooler was installed.
Then suspension/handeling.
Sydney Kid spec Bilsteins all round, still in adj coilover set up.
350lb front springs, 200lb rear springs.
Sydney Kid spec Nolothan front camber and castor adj struttops
Adj castor rods.
30mm front sway bar, approx 26mm rear sway bar.
Nolthan bushes.
1990 r32 hubs, and brakes.
DBA disks, front slotted, lucas high end pads.
motul RBF600 brake fluid.
Braided brake lines all round.
Front strut brace.
Custom made alloy 10mm spacers all round with hub ring.
Dunlop SP9000s front 215/45/17
Dunlop Sport Maxx rear 235/45/17
Hicas lock kit, and lines removed.
ABS half removed.
Most importantly is the set up of the above. It all works. Its almost as high as a stock cefiro, but has unbelieveable grip levels. The ride is nice and comfortable, and I dont have to jack it up to do an oilchange.
Other stuff.
Aircon regassed with the new envro safe stuff.
R33 front seats, the upspec trim that came on CA31s (A31s being standard)
Updated front and rear lights.
Updated front grill.
Respray in red (duhhh)
and side skirts.
Also a front lip was orginally on the car, but as it was about 3inches lower than it is now, it kinda broke.
Stereo
Eclipse 8455 deck (top model, got all the bells and whistles and sounds AWESOME)
MB Quart DSD 213 front splits running of a 2000q cadence amp
JL 10inch 10W3v2 running off a 600s coustic amp, still in a prefab box.
Sound deadening consitis of!
1x road kill door kit
1x tac mat kit
1x 1/2 focal plain chant kit (ie 2 bricks per door)
Acess holes on the front doors filled in with aluminum sealed, and deadened.
and fresh made speaker pods.
fire extinusher.
I'm pretty sure thats it...
https://www.sau.com.au/forums/topic/148468-dds-cef/#findComment-3033630
The absolute best thing about having the car high :sick:
...Oh, and the handling
https://www.sau.com.au/forums/topic/148468-dds-cef/#findComment-3034031
Resin, those pics are pretty old. Its been raised a good 1-2inches at least from then, along with bigger rear tyres.
Had a track day in it today. I dont think my pads are very good for the track... Id in fact go to say hopeless!
But yeah, even with them stuffed I was catching a modded r32 golf! HAHA! And JUST holding off an S4 audi. Mad fun.
Edited by dangerous_daveo
https://www.sau.com.au/forums/topic/148468-dds-cef/#findComment-3049186
Where you racing it dave?
Out at Morgan Park raceway. Its quite fun out there. Just some of the concrete walls are rather close to the edge of the road... Its not too bad tho, just a bit of a worry with power off oversteer.
https://www.sau.com.au/forums/topic/148468-dds-cef/#findComment-3055559
Hey Dave, how often do you go out to Morgan Park and who do you go with? I know the porche club goes out there and the QLD mini car club used to go out there a bit too, I am keen for a run out there one day.
I went out there with SDT the guys we did a few skidpan days with at mt cotton. I do some work for them as well so that helps. Its more of a training day thing, not so much track time. Like you get 2hours or so doing just laps.
https://www.sau.com.au/forums/topic/148468-dds-cef/#findComment-3065824
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
