  • Replies 6k
Posted Images
I left my key in my first car
I parked it in front of the "palaman house" at the first few days i got my lic.
which is a $80+ fine zone + tow away area i think?
i left the car and check if i can park over there
once i got back to the car, i found the door was locked!
and the engine was running too!!!
I looked my keys in the boot of my old VP Commo, the car itself was unlocked but my sub box was blocking up the ski port so I couldn't climb thru from the back seat, ended up locking the rest of the car, catching the bus home to get the spare keys, and back again.
Here's some pretty tasteless Schapelle Corby jokes doing the rounds:
* I was eating dinner in the city tonight and I walked past Schapelle Corby's beauty salon. It had a sign on the door, "Back in 20".
* Did you hear that Victa has released a new model of lawnmower? Its called the Victa "Corby", it holds 4Kg of grass and comes with a 20 year warranty.
* After being convicted Schapelle Corby was handed the death penalty by stoning, so she said, "Give me back my bag and a lighter, I'll do it myself".
* Have you heard of the new fragrance called CONVICTION? It's by Schapelle and lasts for 20 years.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
