  • Replies 6k
Posted Images
nah sam. 4dr 400R kitted gtr would look smick.
yes i know you are just jk but im also just playing along with you.
lol, i realised that after i made the post, whoops.
yeah, something about that 4 door GT-R doesn't look quite right, looks like a cut & shut or something
