  • Replies 6k
Posted Images
i was lucky, most of the mods came with my car FMIC, 3" exhaust, 10psi, pod, tanabe coil-over suspension, and a few more minor mods.
Hows the hunt for the R32 going?
ah, nice one. easier when it comes with the mods how long have you had it for?
checking one out this weekend.. ill try and getr the engine checked out, and if its all good ill make an offer for it.. its pretty stock, exhaust and a couple of things
i think ive had my car for about a year now, i originally was looking for an R32 when i bought my 33, there wasnt really enough R32s to choose from over here, so it was a bit easier to find a nice 33.
Sounds good, if the engines good and the bodys straight and everything is in order! how many have you looked at so far?
dang! ah wells he'll pop his head in here later tonight - when were all asleep!!!
maybe he should be our postwhore where u and me are asleep sam.
:) he can reel off posts like he does on msn, just put 10 down, dissapear for 15 minutes, then put another 10 down
I've looked at heaps online and in the paper and stuff.. but only a couple have been what im looking for .. checked out a couple that you can tell they have engine trouble as soon as they turn it on... so im hoping this one checks out..only problem is, it isnt registered in NSW, so I will have to get a blue slip for it
Dun worry fella's I'm always up late playing VC.. so I can be ur part time nocturnal post whore.. a bit lonely..but hey .. that's country life.. lol :)
thats a pain, you guys have to have all these roadworthy inspections over there, right?
country life? where abouts are you? i thought you lived in adelaide
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
