  • Replies 6k
Posted Images
thats true sam..
Honestly I would prefer to 32.. but thats cos im a fan of the 32 .. So it all depends on what you actually like. look at them both and think about what you would prefer to drive..
We have a 32 and 33 both gtst. So if there are major changes with the gtr variety beside the rb26 then i'd take the gtr33 but becuase its out of my price range atm im contemplating a gtr32 as then its at least has 4wd and a rb26.
so how much are you gonna sell your 33 for duc?
that's the other thing, its seems the market for imports particularly skylines are at an all time low atm. Its hard to say, how much u think its worth sam? Its one thing to say how much i want but another thing is how much the buyer is willing to pay. *sighs
20K neg? you could put more, but it would take a lot longer to sell
