  • Replies 6k
Posted Images
Yeh - sorry my mistake.
Might be worth asking if anyone on the forums has a sander they can lend you.
You can do more with a sander in one day than in a week by hand. (But dont let your girlfriend near it, you'll never get it back) :aroused:
i can get a belt sander but i think they are a no no, care to correct on this sam?
i might just have to go buy an orbitor then now that i think of it.
im sure you are aware that you can change the setting on your alarm sam. Well, leon werent familiar with these alarms so he just installed it for me as it. Ive changed the turbo timer time and yeah my hazards like flash when cooling down. You can make they stay on if you like though, just flick through the manaul and its all there. Its a pain in the bum to program some of the options though.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
