  • Replies 6k
Posted Images
i should be in adelaide on sat, so count me in :rofl:
so should i get the sausages/patties/lamb tomorrow? or do u like it to taste as if it's bland, ie not marinated? hehe
we need more ppl bsides you and me. btw u can see my sanding skills to =/
