  • Replies 6k
Posted Images
all i have to say is nothing is a bolt on kit. It took most of the afternoon - we had to run around for food/misc duties. Performance? I wouldnt have a clue, you would have to ask will that but i recall him saying is that it doesnt make a difference which i then replied its just a safety modification.
btw do you remember the name of the filler that you were going to recommend for me to use on the car - its all sanded back now. Just need to fill some dents and its ready for primer. yipee
btw will is definately serious bout upping the performance on his car sam. When i was there i discovered his pfc, fmic - which we installed and oil cooler. Didnt see any aftermarket turbs though. His getting a tune tomorrow morning supposively @ boost worx.
yeah FMICs don't improve performance - if anything they degrade performance slightly, as they make cars a little more laggy (due to the car having to pressurise a larger volume before making boost). But, they are vital if you want to up boost, and they lower the intake charge temperature to help prevent pinging.
sam, do u want a cai box for your 33? Im going to get will's cai box - the one he bought of max, and fabricate it for 33's and 32's. I inspected it when we had to remove the air filter and its looks quite easy to do as long as i can get the materials. So are you keen?
so you hooked up the pfc too? whats going to happen with the oil cooler, is he gonna sell it or hook it up?
this is the exact cai box will has. I dont know if it does any good would it wouldnt hurt having one. Andrew, would you be keen for one too for the 34? =D If so i would need your car or at least access to its engine bay. =D =D
ive got a home-made heat-shield atm, i would like a full cai box, but money is a bit scarce atm (pooling all of it towards re-build), so maybe later on
hopefully he's going to sell the oil cooler to me. Nah, the pfc isnt hooked up yet. He got george at gt autosound to install it today along with a fuel pump apparently, we were there yesterday to get a hole cut in the engine bay for the fmic and he was talking bout his appointment. Although, I dont know why he's getting/got the pfc installed though because 1/its plug and play which means its basically not hand to install even my sister can do it 2/ it would more than likely be running in limp mode until it can be tuned properly which he's getting done tomorrow at bw.
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
