  • Replies 6k
Posted Images
all i have to say is nothing is a bolt on kit. It took most of the afternoon - we had to run around for food/misc duties. Performance? I wouldnt have a clue, you would have to ask will that but i recall him saying is that it doesnt make a difference which i then replied its just a safety modification.
btw do you remember the name of the filler that you were going to recommend for me to use on the car - its all sanded back now. Just need to fill some dents and its ready for primer. yipee
btw will is definately serious bout upping the performance on his car sam. When i was there i discovered his pfc, fmic - which we installed and oil cooler. Didnt see any aftermarket turbs though. His getting a tune tomorrow morning supposively @ boost worx.
yeah FMICs don't improve performance - if anything they degrade performance slightly, as they make cars a little more laggy (due to the car having to pressurise a larger volume before making boost). But, they are vital if you want to up boost, and they lower the intake charge temperature to help prevent pinging.
sam, do u want a cai box for your 33? Im going to get will's cai box - the one he bought of max, and fabricate it for 33's and 32's. I inspected it when we had to remove the air filter and its looks quite easy to do as long as i can get the materials. So are you keen?
so you hooked up the pfc too? whats going to happen with the oil cooler, is he gonna sell it or hook it up?
this is the exact cai box will has. I dont know if it does any good would it wouldnt hurt having one. Andrew, would you be keen for one too for the 34? =D If so i would need your car or at least access to its engine bay. =D =D
ive got a home-made heat-shield atm, i would like a full cai box, but money is a bit scarce atm (pooling all of it towards re-build), so maybe later on
hopefully he's going to sell the oil cooler to me. Nah, the pfc isnt hooked up yet. He got george at gt autosound to install it today along with a fuel pump apparently, we were there yesterday to get a hole cut in the engine bay for the fmic and he was talking bout his appointment. Although, I dont know why he's getting/got the pfc installed though because 1/its plug and play which means its basically not hand to install even my sister can do it 2/ it would more than likely be running in limp mode until it can be tuned properly which he's getting done tomorrow at bw.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
