  • Replies 6k
Posted Images
ill be taking it easy for a bit, while im running the engine in anyways. what steps did you follow to run your engine in cubes?
Quite contentious, can't say whether I'd follow this advice or not, but it's certainly food for thought. http://www.mototuneusa.com/break_in_secrets.htm
And on a totally unrelated note here's some pictures...
:D
interesting stuff hey. they say if you dont run the engine hard the rings wont bed in properly. i suppose motorcycle engines would have to be similar to the running in of a car engine. coincidentaly the pistons ill be using are CP forged ones, and they make the majority of there parts to suit motorcycles.
Sambo33,
I was conservative and hung off before taking the jump to synthetic.
I used Penrite run-in oil for the first 1500km's, did 3 oil and filter changes.
One after a couple hundred then the other 2 every 600-700 or so.
I then ran Motul Motion 10w30 Mineral oil until the motor clocked up 10,000km's.
Within the 8500km's I did 2 oil changes, each at ~4000-5000km's.
I then went to Motul 8100 X-cess 5w40.
With regards to how the car was driven, I wired open the wastegate so I could get plenty of load on the motor without boost flicking up to 10psi and creating to much load.
The car went on the dyno to check afr's and ignition timing, I rev'd it to 3500rpm and drove with a flat foot everywhere for the first ~1000km's.
After that I began to rev it a little more ~5000rpm.
I only had it tuned and boost hooked back up once i got synthetic and the PFC in to the car which was at 10,000km's.
So it had lots and lots of time for the rings to bed in and properly as I could get a nice amount of load in to her.
Even though I'm running the largest recommended bore to piston clearance for 24+psi and race use it uses zero oil and has no oil in the intake piping.
It did use a little oil and had oil in the intake piping up until around 1,500km's.
It has slight piston slap on cold starts but goes away very quickly. :D
I was told by the engine builder not to jump in to synthetic too quickly as by doing so can only cause harm, not doing so won't cause any harm but only potentially good.
I've bought a few bits in the past week or so, GTR injectors (good for ~270rwkw on std fuel pressure) and a vg30det turbo that I have the exhaust housing machined up to suit a GT30 600hp CHRA and .7 comp cover. :D
I've attached a map trace for those that are fiddlers like myself.
Its also time for another oil change.
I've decided to go with the heavier Castrol 10w60 over the Motul 8100 5w40.
I went a K&N Oil filter over the PureOne this time as i'm tired of skinning my knuckles trying to remove the old sucker. :cheers:
My other half thinks its sad taking pictures of oil ($59.95 @ Autobarn) and a filter ($18.95 @ Sprint Autoparts).
Whats worse is for some reason I get excited when I look at my new oil filter and castrol oil :)
Whats worse is for some reason I get excited when I look at my new oil filter and castrol oil :wave:
They just don't understand.... Do they! How much better is ya car just after a oil change, which reminds me I'm just about due too!!
Oil change.. :wave:
Feels the same to be honest, it didn't use a drop of oil and there was no nasty's in either the filter or the bottom of the drain pan.
I want to get myself one of those cheap oil cooler and filter relocation kits for $175, then grab myself an elec. oil temp and pressure guage and mount it in the center console where the GTR's have their three guages. So many plans, so little money. :D
where can you get the oil cooler and filter kit for $175 i woudl like to know. cheapest ive seen is $350 complete kit.
Sorry $350. lol
http://www.skylinesaustralia.com/forums/sh...ead.php?t=81255
I had just finished looking at the IC for $175. :rofl:
Oil change.. :rofl:
Feels the same to be honest.
i got a Earl's oil cooler coming on early August which i don't need now... crazy1.gif
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
    • Haha good old Letterkenny! If you're looking for another great english canadian comedy, I strongly recommend Trailer Park Boys.
