  • Replies 6k
Posted Images
yeah, im over the whole burnout thing. it pisses me off cos every kid that sees my car drive past wants me to do a burnout. also when your stopped somewhere and someone comes up and says 'do a burnout as you leave'.. grrr. /rant
ive only watched 15 mins of it, pretty good so far. All about gtr's. drools***
if you come down during the week Ill give you a copy inc the drift option i was talking bout before (doesnt have subtitles though DOH!!)
haha i jst got my P's and im over the whole burnout thing, the first night i had my car..... " do a burnout bro " i was like.... wanna buy me sum new tyres then??? the dude was like.... ugh.... nah man im umm right, pffft stupid wankjob
