  • Replies 6k
Posted Images
nah Jar - I will actually be in TIJUANA, MEXICO!!! The wife and I leave for New York Saturday morning, and during our travels will be visiting Mexico in a few weeks time :D
lol @ whiteR33 - nice call - but your sister couldn't possibly be as good as Duc's Momma :D
/end (not-so)subtle fishing expedition
hey thats cool, good ol' T-J :P.... memba to score some cheap drugz eh, jst dont go en-route past bali, well all know what happens 2 aussies there :D.
and with that said im off again, to work i go. how fun, sorting big shipments all day. :lol:
catch ya's later.
Andrew, have you been drinking when you typed this. wdf is my name doing in the same sentence as momma and sister? ;)
anyways, yesterday i was watching aca and it was talking about how petrol was expected to reach the $1.30 very soon. i was shocked to see that it was this price already today when i went to fill up - $1.41 for bp ultimate. now that is getting redicilous.
yeah its bullshit.
they were sayin sumthing about racv campaigning for fuel to go down coz there sick of getting calls from people who are on the side of the freeway coz thete fuel ran out.
i hope there right.... or soon it'll be like 2 bucks a litre. ;)
people doing runners at the petrol station doesnt help either. thats how bad and desperate the situation is. it just gets worse and worse, missisipi is flooded, new orleans isnt any better, oil is increasing in price due to shortages. Guys, the world is going to end soon!!!!!
from what i understand there is no shortage of oil, there is still an abundance of it over in the arab countries. i think the US and it's pointless war is to blame...
i hear unleaded is going to be at 1.60 in the next few months..
180, seems the car is overheating and that it has not been able to rev out freely while driving as though its struggling to move for some reason. means its just more money that can be used for other things going into fixing this. **sigh**
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
