  • Replies 6k
Posted Images
i was considering a e30 for a run about.. or a rolla. But with my new job i found myself directly in the city, so ill prolly start busing it soon.
Yea Sam thats the goods, plus some other stuff ;D
E30 beema? nice choice, I had a E34 5 series before i bought the Line, be a good daily but hey if your only 1 bus or train or tram ride to where you need to be, thats prob better again, especially in town! parking n shit.
So Duc, none of your beasts will be out on Sunday?
unfortunately no they wont be which is a shame. :P
im having a bad run of luck atm with cars, if its not one things its the other. i still want to meet other skyliners though thus the ride in Sam's car. plus its likely going to be the route that i pm'd you Darren. Do you have any suggestions to expand on it? if so pm Sam your ideas.
ok
starting get beyond the joke tonight paid the to price of 1.48 litre tonight
bout time we rebeled bout this fuel shit gov has a option to help aussies out but is make a pretty hard stand, so maybe we should
any ideas
yes. the govt does tax on petrol, they should drop or at least cut it out. but i cant see that happening, greedy bastards would hate to lose out on any cent they can get
unfortunately no they wont be which is a shame.  :unsure:
thats a nice route through the hills, there is a bit of everything in there :D
i would like to take it a bit further, but i guess it depends on how far everyone wants to drive?
HEY!!! :lol:
yep, sunday, hopefully the weather is as nice as it was today. looking forward to a big drive cos i havent driven my car all week.
btw, petrol was 1.45 last night filled up 3/4 tank & cost me $60 :S
not doing much tonight, too stuffed from work + not enough sleep
prob clean the car tomorrow, and go for a drive somewhere. been driving the pulsar all week and im itching to go for a decent drive in the skyline
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
