  • Replies 6k
Posted Images
went on a mini cruise last night with 3 other GTRs, 2 WRXs, and a RX7 S6 to Lobethal and back. Had issues with losing cars in traffic though. Engine was hot and brakes not as reponsive on way home but it sure was fun!
not sure about that one.
i always put BP in my car, execept i ran out last night & the BP was closed so i had to fill up with shell, starting off for the first 5 minutes i took it easy then i went up to about 4500RPM in third and got a knock reading of 75 on the PFC!!! im gonna wait till this tank runs out & im never going to put shell fuel in there again
Sam, Shell don't sell 98 octane fuel in SA, so if your car was tuned using BP Ultimate 98, putting Shell Premium (95 RON) is definitely NOT a good idea with an ECU with no knock control.
To be honest mate, I'd drain it and refill - it might be $60 worth of juice, but how much was that rebuild again? A LOT more.
Oooo, i havent been on a good run for ages! nice weather at night now for it, can actually get out the car and chat without getting drenched.
Also, I'm going for the Microtech to solve my problems, so car should be back at christmas time :(
hope all goes well for ya steve :D
thanks for that info will, i didnt know the shell was only 95RON.
i didnt put much of the shell fuel in there, just enough to get me by. so today i filled it up the rest of the way with BP and its running all good now.
from what ive read the knock reading of 75 isnt too serious, but ive learnt a lesson there.
with that first 4000RPM right before the boost really kicks in, the computer over-richens the air-fuel ratio, not sure why, but thats why it goes all flat. i noticed my car used to back-fire a lot around those RPM, but now it rarely ever backfires
i was originally going to, but i ended up getting it fitted & tuned all in one. i also needed a bosch fuel pump, cos the stock one was running out of puff. i got boostworx do do mine, they did a top job. but i also heard good things about graham west too.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
