  • Replies 6k
Posted Images
Hey i remember this thread :)
how are ya Darren? hows the 33 going?
Hey Sam the 33 aint going nowhere....have decided to take it off the road after it started funking out on me. AFM, Fuel Pump, Clutch Rebuild, Cradle Bushes, Full Lube flush + service and a full FC retune is in store, so unsure when she'll be back!!!
hey Darren, whats involved in fitting new rear cradle bushes to an R33??? I hear its a pretty big job?
With the Zenith ones you have to drop the whole cradle, to purchase the Zenith ones they are $120 plus my bro in law can fit them for you for $55 P/Hr 1 1/2-2 hrs, or can supply some basic instructions.
Thats the way Sam, yeh we generally get the the Ed about 11am and have to line up, is usually a solid 12hr affair but being on the Sat people won't have to work, so i think we will be gettin there a bit earlier........you sould try and drag Duc there(not like he won't read this!!!!)
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
